Question Problem with FPS in Warzone ?
Dec 31, 2024
4
Hello, i upgraded my CPU from Ryzen 5 5600X to Ryzen 9 5950X so i dont know why but im facing low FPS max to 80 in Warzone at 1080P gaming, while i saw some videos people play easy at 120-130 fps. I also tried many other settings but same not moving from 80-85, also all my drivers are to last updated, bios also to last version.
In other games like Player Uknown Battlegrounds I'm getting 135 - 144 fps.
CPU Specs:
CPU: Ryzen 9 5950X
GPU: ZOTAC GAMING GeForce RTX 3080 Ti Trinity OC
CPU FAN: CM ML240L RGB 2.0 White Edition
Motherboard: ASROCK X570 TAICHI
SSD (M2): KC3000 PCIe 4.0 NVMe M.2 SSD (using for Windows/Games)
SSD 2 (M2): A400 NVME (using for apps programs etc not games or game clients)
HDD: 2TB WD Green SATA HDD (using for some other stuff)
RAM: KHX3200C16D4/16GX (Kingston HyperX with RGB 16GB)
RAM 2: DIMM 16GB DDR4 3200Mhz Geil CL16 Orion (16GB)
PSU: Coolermaster Silient Pro 850W
CASE: Cooler Master MasterBox TD500 Mesh White
TOTAL RAM: 32GB
Monitor: MSI Optix MAG271CR 144HZ
OS: Windows 11 Pro
Hwinfo:
https://prnt.sc/HAAvm3nVyOza
cpu/gpu temp and usage during the game?
The TEMP of CPU goes 65-70 celsius , while gpu goes up to 75 celsius
There no problems with temp they normal, i also didnt overclock or something, and i use thermal grizzly kryonaut extreme for CPU, and except the CPU cooler i have additional 4 coolers to case all are coolermaster brand.
5950x isn't an upgrade from the 5600x for most games. If you look at the reviews it's almost perfectly in line with the 5600x in terms of fps.
So you'll likely see no fps improvement with the upgrade.
Assuming the resolution your running is the same as those your comparing to?
Did the fps decrease or stay the same with the 5950?
technically not true for some games want more cores i didnt see much benefit in some titles others overall more stable framerate with extra cores.
CPU Specs:
CPU: Ryzen 9 5950X
TOTAL RAM: 32GB
OS: Windows 11 Pro
Hwinfo:
your ram is mismatched and thus could be causing peformance loses.
does the nvme kc 3000 have a heatsink
Latest posts
