Problem with freezing hard disk Samsung 2TB HDD
boss1983
15
Sometimes freezing no reasons ..
HD Tune Pro software malfunction appears that yellow stripe picture
[/URL][/img]
If the hard disk is dying? I need to buy a new hard disk?
Hmm, not the best thing. First of you should backup any files that are important to you asap. Also another thing you can perhaps try doing is using a Defraggler then see if it goes down from 17. However it might not resolve anything... You should think about buying a new HDD.
Hope that gave you some insight, let me know how it goes. If you don't have further questions remember to select a solution. Good luck.
I personally use Power Defragmenter, however I've always heard good things about PerfectDisk. So yeah that one will be fine to use.
Edit: Oh btw, make sure you do it when you have lots of time to spare. It can sometimes take a couple hours so it's good to leave it on when you go out etc.
