Problem | with GeForce GTX 260 driver
Killerscript
5
well...
it's started two weeks ago,
i waked up in the morning, resume to use the computer, and then suddenly he got freeze.
sooo i made a restart, but when i opened Google Chrome, he made wired display, black boxes around the sceen.
so i thought that the problem is with the video card, so i updated it to his lastest version but it made worst...
so i came back to my old version, and here is how my sceen looks when i using "Unity3d games engine":
http://imageshack.us/a/img713/8461/problempic1.png
http://imageshack.us/a/img543/3433/problempic2.png
also, and if you want, this is my dxdiag log :
http://www.2shared.com/document/C-Dt1h58/DxDiag.html
i can't get the reason, cause it doesn't happedned before!
everytime i'm openning this software is get stuck and freeze, and when i open a lot tabs of Google Chrome it get stuck, and when i'm playing 3d games it get stuck.... i can't do anything with the computer....
WHAT IS THE PROBLEM!?
check your gpu temps and voltages. looks like a lot of artifacting. cause by either a bad overclock (set it back to default) poor cooling, make sure the cooler isnt clogged with dust. poor voltage controls... make sure the gpu is phasing correctly when load increases by watching the volts go up and down on the vddc. (vrm/voltage regulator module).
use msi afterburner to check the volts and gpu-z to check the vddc.
Killerscript
5
1.how do i check my gpu temps and voltages?
2.how do i set my overclock to deault?
3.how can i know if my cooler clogged with dust or something else?
