Problem with Gigabyte 78LMT-USB3 Motherboard
Prateek Bhardwaj
35
Hi,
I recently purchased Gigabyte 78LMT-USB3 Motherboard, 8GB Corsair Vengeance DDR3 Ram 1600MHz, AMD FX 8320 Processor, Sapphire Radeon HD 7770 1GB GDDR5 Graphic Card and A Zebronics Gold 450W PSU. I have a 500GB WD hard disk which is working on my other PC. When I insert that hard disk on the new PC it shows the windows logo and restarts everytime I try to boot. Someone please help. I have a doubt about the RAM it being 1600MHz and the Motherboard Supports 1333+ OC. What does that mean? And If the RAM is faulty will it go to the Window Logo in the first place.
Did you do a fresh install? If not, then that's the problem. For new MoBo's you need to do a fresh install in order to replace the drivers...there are ways around it but a fresh install is always best.
Thanks a lot man for the quick reply. Will do and let you know if it cures the problem. Thanks a bunch.:)
That will do it...tried one upping an OEM copy of windows onto a new MoBo to save some money...read how too's on google that say cerain methods will work....followed it to step by step completely...short answer? same thing that's happening to you happened to me...I knew the answer right away...I had to drop 80 bucks onto a new copy of windows 8.
