Having a problem with my graphics card (ATI 6770 1GB DDR5) So when my computer starts it start from DVI Output into windows 7 loads up until the blue screen with Welcome on it. just before it reaches that stage it stops working.
I have reinstalled chipset drives into the motherboard, and tried installing the graphics card drivers however the same problem still occurs. I reset the motherboard bios to default settings meaning it should use the graphics card out but this did nothing. I have had the actual graphics card checked and it works fine.
I can only get VGA output from it and this is really bugging me as i cant play games without the installed graphics card.
Also the Wireless LAN Card sits below it on the PCI Slot and that works fine, just nothing from the PCI-E.
Here are all my system specs.
ASUS M5A78LM L-X (motherboard)
ATI 6770 1GB DDR5 (Graphics)
8GB DDR3 (Ram)
AMD FX-6100 3.3GHz (CPU)
500GB SATA HDD (Hard Drive)
RALINK 802.11 Wireless LAN Card (PCI Slot)
And a bog standard DVD-R Drive
Any suggestions or fixes greatly appreciated.
Thanks!
8GB DDR3 (Ram)
Thanks!
