Question Problem With graphics card
Aug 16, 2019
hello! i bought a RX 560 and i have a Ryzen 3 2200G with its own graphics card..so i didht unistall any drivers since they needed the same which i had installed so i connected the gpu to the motherboard and powered on the system since it didht need power connection so i turn on the pc and i get black screen..then i unistalled the graphics card and the tried with the ryzens graphics and still black screen.. what can i do..lights fans are working what can i do??
Aug 16, 2019
List FULL PC specs. Do you have the latest BIOS installed on this system ? Clear and reset the CMOS/BIOS settings, and then try again. Did you plug the Monitor's cable to the GPU ?
Asrock RX 560 4GB
8GB RAM
MOBO Asrock A320M DVS R1.0
i have tried cmos and still no luck
