Problem with Hardware or Software
G
Guest
Guest
The situation is this, my dvd's run smoothly with no problem for 4 minutes. Then, by the end of the four minutes, my sound goes out. This ALWAYS happens. I'm using Powerdvd and i tried it with two different dvd's. i'm pretty certain this is b/c of software but i'm affraid this might be b/c of hardware. Any suggestions?
marty123
17
Powerdvd dies this if it is a copied program, I think you need to register it or else you can only watch the first 5 mins of something.
I have been asked to edit this post, so I have now. I have taken off the serial number<P ID="edit"><FONT SIZE=-1><EM>Edited by marty123 on 11/02/01 07:22 PM.</EM></FONT></P>
Toejam31
2,989
What version of Power DVD are you using? Does it detect your video card and sound card correctly?
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
____________________________________________________
<font color=blue>"Does history record any case in which the majority was right?" ... Robert A. Heinlein</font color=blue>
Toejam31
2,989
No "cracks" on the forum, please. This is not a good idea. This is <i>not</i> a warez site, and Tom Pabst may not be very appreciative of you helping someone in this manner on his site. If you must send someone this kind of information, do it by email or with a private message ... not in a public area. I suggest that you edit or delete the post.
Toejam31
Toejam31
2,989
Thanks, marty123.
Hope you are enjoying the Forum!
Toejam31
