problem with hdd after using aomei
hardbg123
32
Aomei dynamic disk manager problem.
So i used aomei to copy os from ssd to a hdd becuase my flash drive didnt work. The problem is that after i copied the files from the ssd the hhd which was 1tb now shows only 240gb (the ammount of the ssd 1:1 copy without the speed)
AOMEI is basically a user friendly GUI for Windows Disk Management. I don't think it is intended for cloning, which is perhaps what you attempted to do?
Either way, if you copied a 240GB partition to a 1TB drive, then there should be unallocated space that you can use to extend the drive, or create another partition.
