Problem with HDMI connection from 1070 to Toshiba TV 39 39l2353d - the image is blurry and goes outside the screen
Yavor Raychev
Commendable
Aug 16, 2016
Hello.
I was using DVI-I to VGA adapter on my previous card and VGA cable to the TV and had amazing image.
Since I updated to 1070, the car doesn't have anymore jack for analog signal, only HDMI and DVI-D and thus, i am not able to transfer analog signal to the TV without using active transformer (as far as I know at least).
I bought HDMI cable and connected it to the monitor, but the image is really bad. There are a lot of noise in the photo, sometimes it is too blurry, sometimes the image is too sharp.
In order to fit the image on the screen, I used Nvidia settings, because my TV doesn't have anything related to that in the menu options
I didn't find also PC mode or something like that in the menu of the TV. I am not sure if the HDMI is adapted for PC HDMI, but I didn't see any settings i could use to adjust manually, except sharpness - reducing it from stock one seemed to have improved the image, but not enough.
Also I think the signal which is being sent to the TV is fine, since i took screenshot and the screenshot actually looks pretty well on the phone. This can be misleading, since the phone display of course is smaller and I do not have other monitors or computers to test myself.
What could be the solution to this problem?
You have overscan enabled. Go to the TV's image settings and disable overscan (sometimes the mode you want is "dot by dot" or "1:1")
