I recently bought a factory OC'd refurb. I wanted to see if I could OC it some more, so I downloaded speed fan to see what the temp was. I was surprised to find the CPU idling at 58-60C and the GPU at 66C. The only fan I could easily control is my GPU fan using the Nvidia utilities. I tried changing it from the default 30% to 100% This made the CPU and GPU temps drop in step (each drops at the same rate) so that they each dropped 8-10 degrees C.
The problem is, my GPU fan is on the opposite side of the card from my CPU.
See this picture.
My question is, how can I make my CPU temp drop without running my GPU fan so hard. It's very loud. The orientation of the two fans is that the top left one blows out of the case, while the CPU fan blows into the CPU. The case has a large perforated rectangle that extends from nearly the top to the bottom, in line with the CPU fan and GPU exhausts.
See this picture.
