Problem with HP cartridge no. 344
Jd
470
Archived from groups: comp.periphs.printers (More info?)
On week-old HP 6540d printer, I'm getting following error:
There is a problem with the Tri-color Print Cartdridge.
To solve the problem:
1. Remove the print cartdridge.
2. Re-insert the print cartridge.
If the problem persist, Replace the print cartridge.
The printer won't print anything with this cartdridge inserted, except
the cartridge check page (power + x button). Additionaly, the driver
shows, that the cartdridge is empty, but it isn't (it is new, after
all).
Is there any way, how to get it working? I'm not rushing to buy a new
cartdridge, because this same could happen again.
"JD" <john.johndoe@gmail.com> wrote in message
news:b088d15d.0504200345.3c934480@posting.google.com...
> There is a problem with the Tri-color Print Cartridge.
> 1. Remove the print cartridge.
> The printer won't print anything with this cartridge inserted, except
> shows, that the cartridge is empty, but it isn't (it is new, after
> all).
> cartridge, because this same could happen again.
You might try cleaning the cartridge contacts as shown at
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&dlc=en&docname=c00058182
It is also rare but possible that you have a cartridge that has failed. In
that case contact HP or your dealer, they should replace the cartridge under
warranty.
Regards,
Bob Headrick, not speaking for my employer HP
> warranty.
The same happened to my new black ink cartridge on my HP 3520. With
color cartridge it's fine, as soon as i insert the black one - it dies.
Happened twice (i returned the first one, the same happened with the
replacement i got).
Yeti
the abominable snowman
http://www.semenka.com
"Bob Headrick" <bobh@proaxis.com> wrote in message news:<116con6fac5js31@corp.supernews.com>...
> warranty.
> Regards,
Thank you for you help, Bob.
Cleaning the cartdridge and printer contacts did not help.
It is interesting, that the cartdridge did work out of the box. I
printed the sample page (the fruit picture) and one page with my own
image. Then, few days later, while printing B/W lineart, it started
complaining about color cartdridge.
The power + x button test page shows following:
56. STAT = 8
57. LOI = 95
66. STAT = 0
67. LOI = 91
Other lines are the same for color and bw cartdrige, and the color
patters are printed too.
news:b088d15d.0504210133.56056b53@posting.google.com...
> 56. STAT = 8
> 57. LOI = 95
The Stat=8 indicates a problem with the color cartridge, the LOI =95 means your
cartridge is nearly full. Please post here or email me the contents of 52 and
53. I do not know about the support in your country; if you were in the US I
would suggest you call 1-800-HPINVENt for warranty service, the would send you
a new cartridge. You can find contact information for your country at:
http://welcome.hp.com/country/us/en/wwcontact.html .
Regards,
