PROBLEM WITH HYUNDAI NOTEBOOK
saimon
Archived from groups: comp.sys.laptops (More info?)
Good morning,
I have a little problem with my notebook
HYUNDAI P4 2.8 Ghz with 512 Mb RAM
If I leave my notebook on for about 8 9 hours,
the performance are very bad, because to swap from an application to an
other , the system start to wite/read from/to hard disk and the operation is
long about 1 minute.
If I try to turn off the notebook, the operation is long about 10 minutes.
Why ?
Is this a memory problem or anything else ?
Thanks for the answers.
Saimon(FI - ITALY)
G
Guest
Guest
Saimon wrote:
> Good morning,
> an other , the system start to wite/read from/to hard disk and the
> operation is long about 1 minute.
> minutes.
> Why ?
> Saimon(FI - ITALY)
Open Control Panel/System/Hardware/Device Manager. Open IDE ATA/ATAPI
Controllers/Primary IDE Channel/Advanced Settings tab. For Device 0,
transfer mode should be DMA if available, current transfer mode should
be Ultra DMA Mode 5. Device 1: Auto Detection or None, DMA if
Available, None Available. Check Secondary IDE Channel, it should be
the same as Primary IDE Channel, Device 1 except Ultra DMA Mode 2.
If these are PIO Mode, and cannot be changed, then you should look for a
chipset driver and/or BIOS update from the vendor.
Check this site - it's English, maybe you can find an Italian
equivalent - the site describes steps for checking other issues for a
slow computer. Follow each step.
http://www3.telus.net/dandemar/slowcom.htm
Q
