problem with i5-4670k
louddifference
42
ive just recently built my new gaming rig and its been working for about a week, but now when i try to boot or come out of sleep, it does produce a image or post and the cpu led is on. i have to keep trying to turn it on, sometimes taking 5+ times.
i have no idea what is wrong and i need help!
also when i built my comp at first i had a psu that didnt have support for the gpu i am getting, so i returned it and at the store they tested it and said it was defective, my new psu is a tx850 by corsair. so could it be that my new psu is bador my old one fryed something?
help! 🙁
Your motherboard most likely has a button somewhere (maybe in the back where your other connectors are) to clear CMOS. Alternatively, a jumper on the motherboard would do it. Consult your manual.
If you can manage to get into the BIOS, you would be able to reset to default settings through there as well.
One last thing to check would be the power cord and outlet you're using. Do you have the power cord plugged directly into an electrical outlet? If not, try that. Probably won't make a difference but it's worth checking.
Honestly, at this point I would try either a different motherboard or different CPU, leaving everything else in the system the same, then report back.
So, to clarify, you meant to say that whenever you try to take it out of sleep or power it on, it does NOT produce an image until you attempt it 5+ times?
If so, am I correct in assuming that you are indeed able to get it running at some point?
If that's the case, it's probably not the CPU -- generally, a dead CPU won't boot at all. However, stranger things have happened -- for example, if the CPU was overheated to an extent that it crippled it.
However, most likely it's another component causing the trouble. My first thought is the motherboard, but let's examine the PSU first.
What brand and model was that original PSU? A faulty poor quality PSU can kill or damage components, so that is a pretty reasonable guess. It's possible your new PSU is faulty, too, but less likely. That's a pretty solid unit. Can you have it tested at the store?
Other than testing your PSU, I would first make sure all your power connections and interface connections are secure, everything is hooked up where it should be, RAM is seated properly, Motherboard is on standoffs, graphics card is seated and powered properly (if you have one. You said "GPU I am getting" so I'm not sure if you're using one right now or not), CPU cooler is installed correctly and making proper contact (and has thermal paste) -- the basic stuff that perhaps you've already checked.
If all that checks out fine and you're still having problems, I would swap out only the motherboard (maybe a shop can loan you one?) and see if that helps. If that's not the issue, try swapping RAM or using just one stick of RAM (or you can try the RAM before the motherboard since it's much easier to swap out). You might also consider trying a different CPU if you can borrow one, or trying your CPU in another machine if someone will allow it.
Let me know if none of those things solve the problem.
Also, do you have an internal speaker connected to the mobo? If so, does it produce any beep codes? I know you said the CPU LED was lit, but that can just as easily indicate a bad motherboard that can't communicate with the CPU. In that case, I'd also check for bent pins.
well i have already checked my ram and its good, my standoffs are all in place and my gpu i have for now is in properly. when i was getting it started today i opened the side and pushed the cpu power cable toward the mobo more and then next try it booted, so itr could have just been a dumb error by me but probably not, also the psu i had before was a ultra lsp650 650w atx psu.
Make sure that CPU cable is totally seated and properly latched. You shouldn't be able to pull it out without unhooking the latch. That would certainly be convenient if the problem was simply the CPU cable being a little loose.
Latest posts
