problem with ide cables hard drive and cd drive
da_kurlzz
18
alright i mad a new pc for my sister
but i cant get in because the ide channel and cable is not working its not identifying the hard drive and dvd player
is there a solution on how to fix this it seems i tryed evreything but it just wont work
also i tryed switch to an othere ide cable but same thing happend
pogsnet
417
Replace IDE cable with new one. It happens when you accational remove the HDD or CD-rom. Or convert them to SATA. There are IDE to SATA coverter. But for sure replace them with new one. ")
ailgatrat
179
On some asrock boards you have to have the hard drive and cd/dvd drives running off of separate ide ports. Could be the case with your board as well.
pogsnet
417
The jumper must be slave to the other one and master to the other. Or try using atleast 1 of them. Maybe 1 device is defective or your PSU cant powerup them both.
The ide to sata or sata to ide converter usually made from hongkong or shall we say China. I don't know if you can find that on Canada. It costs less than us$10.
