I have a Intel DQ65GF motherboard that has worked great for years .Recently I decided to toy around in the cmos and changed the ram setting from 533mhz to 667mhz to match the listing on the ram I have installed . After reboot I get no post no beeps all fans power on but nothing else happens .
I have tried resetting the bios multiple times removed all components aside from the cpu and fan it did beep like crazy as it should with no ram . I have tried different ram no changes . Verified all connections including mounting screws . Tried other psu's .
I tried a different mobo as well though I am not sure of its working condition it was new but got exposed to moisture and has a small bit of rust around the audio jacks it gave me a single beep with ram installed but also did not post.
System worked fine before the change in cmos at this point I am completely clueless on what could be wrong if anyone has any suggestions on how to fix this or even if I should be looking into the mobo or cpu have gone bad from this change I would be greatful
Specs Intel DQ965GF mobo .Unsure of revision number at this time as I cant get to the tower ( In the closet blocked off by xmas stuff)
Intel celeron 3.33 GHZ cpu
2gb PC25300 ram
2gb PC25300 ram
