Problem with internal speaker (no beep/post sounds)
Mikel12
4
Hi there It's my first time asking online.
I would appreciate if someone call help with a problem I have.
I have D945GNT Motherboard.
It worked before I moved a place, I came back home (6-12 months) and it doesn't work now.
I tried to replace Ram, Video card (tried VGA and DVI ports), Power Supply.
I cleaned it from dust (mostly).
It had an internal graphics chip I think.
When I turn it on it just works (everything works, fans work fine)
But I don't hear any beeps or post sound and there is nothing on the screen.
Even I turn it on without RAM it still doesn't beep.
I tried to look at the mother board and as the manual says there is an internal speaker but I don't see how I can replace it.
I want to hear beeps so I can troubleshoot the PC.
Any ideas what can I do ?
(link to the image, the speaker it that circle shape with a + on a yellow background
Thanks
So, there is no pins for a case speaker. The built in speaker is not working. Guess you'll just have to go with that or get a newer board.
If I already have the external one ? can I get out the internal one and replace it with the external one ?
And if I cant replace it, Where do I connect it ? (I didn't see any space for an external speaker on the mother board)
Thanks
None show something related to Speaker.
Thanks you very much
