Problem with Kingston SE9 16GB Flash Drive
khanorak
17
Hello Community,
I have a Kingston SE9 16GB Flash Drive (USB 2.0).
The problem with this flash drive is that when I try to write any file to the flash drive, its speed keeps fluctuating between 2 MB/s to 5 MB/s in a very strange manner.
for example, If I am to transfer a 1GB file to the flash drive, it would be about 10 MB/s in the beginning, then it would come down to 5 MB/s, then 2 MB/s. It would rise up again to 5 and then back to 2, stay there for a second and then repeat. It looks like it pushes 5 MB of data every second and then flush the cache again or something, thus taking time.
I am attaching a Pic to clarify it. It takes a lot of time in this way, way more than any other flash drive. See the small peaks indicating some high fluctuations.
1. I have tried turning on the Performance mode; same results. Is there any other way to increase cache or something?
2. and there is no option in BIOS to turn off legacy USB support feature off.
3. I have tried copying files with NTFS, FAT32; Windows 8.1,8, 7 - all the same.
4. Same performance across multiple computers.
Plugged into USB 2.0 and 3.0 ports, same results.
In your case the ssd should not cause the bottleneck. Even the usb 2.0 port is capable of an average file transfer of around 30 MB/s. It could in your case be a bad usb port, bad usb 2.0/3.0 controller or a bad flash drive. I suggest you try the drive on a different pc and try a different flash drive in your pc to reduce the number of possible faults listed.
This is very common when transferring files. The reason is that windows loads some of the files to the RAM to access them quicker than if they were being read of the HDD. Therefore, the transfer rate is the fastest when the data is being copied from the RAM. Afterwards, the HDD bottlenecks the file transfer.
Oh, I guess I didn't mention. I have a Kingston SSD and I think hard drive would not be the problem. I guess it is the Flash drive then which is problematic(?).
