Problem with Lexmark Z515
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hi,i bought this printer a while back, and it had been working fine,
but now I am getting a
Lexmark 510 Series: USB 0001
The printer cannot communicate with the computer
Try these solutions:
-Disconnect and reconnect the USB Cable[Which I have done]
-Disconnect and reconnect the printer's power cable[Ditto]
-Restart your computer[Ditto]
I'm using a USB hub, with 3 other devices, each of which work; I have
tried it without using the hub though
Any solutions?
Thanks in advance
Matthew
Make sure you plug the printer into the same port where it was installed.
Or, delete the printer from the printers list and re-install it.
Do a Add/Remove and remove all the software too.
Then re-install the driver
Make sure you wait until the bubble says "your new hardware is working"
before using it.
ER
<mckeever-m@ulst.ac.uk> wrote in message
news:1127232401.768075.325220@z14g2000cwz.googlegroups.com...
> Any solutions?
> Thanks in advance
> Matthew
Good advice, but with Lexmark it is a waste of time, Evad.
"Evad Remlu" <evad@dodgeit.com> wrote in message
news:433037a8$1_1@x-privat.org...
was installed.
re-install it.
> before using it.
> ER
working fine,
done]
cable[Ditto]
work; I have
> > Any solutions?
> > Thanks in advance
> > Matthew
