problem with messenger
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
can you please tell me why when i sign in on msn
messenger i get a pop up in bottom corner saying i have
signed on ,on another computer when i havent. thanks
Greetings Karen,
It sounds like Windows Messenger is being loaded in the background. You'll simply need to
disable Windows Messenger. To do so, open it up (click Start, then Run, type "msmsgs" and
click OK), click Tools, Options, Preferences tab and uncheck 'Run this Program when Windows
starts' or 'Run Windows Messenger when Windows starts' (depending on version) as well as
'Allow this program to run in the background' or 'Allow Windows Messenger to run in the
background' (depending on version). This won't remove Windows Messenger, so features like
Remote Assistance, Whiteboard and Application Sharing will continue to work, but it will let
it stay out of your way.
Also, do you have Norton Antivirus installed? Recent versions of Norton Antivirus added a
new "instant messaging scanning" feature, which can conflict with Messenger and cause it to
also keep starting. To stop it, open Norton Antivirus (Right-click on the Norton Antivirus
icon in the System Tray/Notification Area (by the clock), choose 'Open Norton Antivirus'),
click Options, then Instant Messenger then uncheck MSN Instant Messenger and click OK.
Finally, you may want to reboot to make sure that its not loaded after this.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"karen shipman" <karen@shipman6.wanadoo.co.uk> wrote in message
news:10e201c4bb5a$646a10e0$a601280a@phx.gbl...
