Problem with Mini Bluetooth ELM 327 OBDII
lynx961
Guest
Jan 25, 2013
44
Hello
I have the mini blue ELM327 (OBDII).
I use torque for android. It works on all kind of cars accept Nissan VERSA.
When I use it on VERSA torque gives me this error.
ECU problem
The ECU is reporting that it does not support the reading of any PIDs.
Your vehicle may not be OBD2 compliant OR the vehicle ECU has not been enabled by your dealer/manufacturer for OBD2 access
Torque will probably not be able to retrieve information due to this problem
The link of the OBDII is:
https://www.aliexpress.com/item/ELM327-v1-5-Mini-apply-to-all-OBD-MINI-ELM327-Bluetooth-OBD2-V1-5/32334039714.html?spm=2114.search0104.3.105.c7f643c0RPPWbd&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_204_318_319_10059_10884_10887_100031_10696_450_320_10084_10083_10103_452_10618_535_534_10307_533_532_448_449,searchweb201603_60,ppcSwitch_0&algo_expid=4a4f39df-e6db-4c46-800e-f77a5d6128b8-13&algo_pvid=4a4f39df-e6db-4c46-800e-f77a5d6128b8
Any help about this problem?
Thanks
