Problem with "MMDEVLDR.VXD" that can't be loaded.
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.soyo,alt.windows98,comp.sys.ibm.pc.soundcard.misc (More info?)
Hello people. Sorry for the crosspostings.
This is for a friend:
He has a 750MHz Duron PC with a Soyo K7VTA-B motherboard, using the onboard
audio (AC'97). After he deleted some stuff, he lost all audio.
Winamp gave the "MMSYSTEM002" error.
I tried the obvious (remove drivers, reinstall drivers) but it don't work.
When I go to device manager, there is a '!' sign in the icon of the "sound
card", which means a warning/error.
The error says something that "NTKERN.VXD can't load MMDEVLDR.VXD".
BUT, both files exist!
Question: Has anybody here seen the same error with this motherboard, or any
others that have AC'97? What did you do to fix it?
OS is Win 98 SE.
[]s
© Chaos Master. |"These wounds won't seem to heal
Posting from Brazil. | This pain is just too real
http://marreka.no-ip.com | There's just too much that time can't erase"
(most often offline... ) | -- Evanescence, "My Immortal"
> onboard audio (AC'97). After he deleted some stuff, he lost all
> audio.
> work.
> "sound card", which means a warning/error.
> or any others that have AC'97? What did you do to fix it?
> OS is Win 98 SE.
> []s
in device manager remove all references to sound functions.
then shutdown and restart. have the cd ready to reload.
