Problem with mothercard installation
Jun 1, 2018
I already installed the cpu, cpu cooler and memory on my motherboard.
But the problem is I can't put it into my case. It a perfectly compatible case, but when I tried to fix it in I can't aline it with the motherboard shield.
I tried my best but I don't want the mother card to break, so I don't know what to do. I looked to some tutorial on internet where it seemed really simple but for me it is very difficult.
If you have any response for that please respond.
Could you post your system components.
Make sure the standoffs are in the correct locations on the case to keep the motherboard above the case and prevent from shorting it. Some cases might come with standoffs installed but they might not match your motherboard.
Make sure the I/O shield is properly installed (correct direction) and apply pressure to all four corners of the panel to secure it into the case. It should snap into place
Gently but firmly force the motherboard against the I/O panel until the ports (VGA, DVI, sound, NIC, etc) are inserted into the I/O back plate.
You might need to hold the motherboard to align it with the mounting holes, since the I/O back plate might push the motherboard back.
