Question Problem with mouse after replacing its cable and skates ?
_ThunderClap_
Commendable
Oct 1, 2021
86
4
1,545
I recently changed the USB cable of my Logitech G402 mouse and replaced its skates, but after doing this the mouse has become very sensitive to the mouse pad surface. At some areas of the mousepad it will respond according to its set dpi but in some areas it will slow down a lot. Also when the mouse is sitting Idle the cursor moves left and right rapidly on its own. The mouse worked fine on this mousepad before the replacements were done. Everything is the same as it was before replacing the cable and skates.
It could be the skates and the height difference. You could try adjusting your lift off difference to a little higher to see if that makes a difference. Other thought is it could be your new wire and you are getting in consistent feedback from the mouse to the PC, so it just seems different.
I would say if it is always the same area of the mouse pad it acts different than LOD is more likely. If it is just random or inconsistent, it could be your cable sending the input. Try the LOD first to see if that makes a difference. Only two things have changed, so it is one of the two, the cable or the skates (which will impact LOD).
Can you please pass on a link to the skates you'd used as replacements? It seems to me there might be a discrepancy with the highest of the mouse's laser and the surface, which is why I'm assuming the feet are the issue, not the cable.
Then again, what cable did you swap it out with?
https://www.aliexpress.com/item/100...der_detail.order_detail_item.3.22b7f19clv7V8B
Both the cable and skates are cheap replacements I bought off aliexpress. The skates were included with cable.
Reactions: _ThunderClap_
