I have been running MS-DOS with Windows 3.1 on an old early Pentium spec computer for nearly ten years without any problems.
All of a sudden, completely out of the blue I started to receive the following message when booting into MS-DOS: 'Microsoft Mouse not found, try another 9 or 25 pin serial port and/or check for interrupt conflicts with other peripherals. Type Mouse /f to check all ports'.
So I typed mouse /f and all that does is repeat the error message. I installed Microsoft Mouse 9.01 (full package) years ago and I was able to use a mouse in true MS-DOS as well as Windows.
To troubleshoot the problem I tried the following:
Entered Windows 3.1 - the mouse is not working there either.
Plugged in another mouse that is known to be working to rule out a defective mouse.
Tried connecting to a different serial port to rule out a defective COM Port cable.
Tried installing a different hard disk with a fresh install of MS-DOS & Windows.
Entered the BIOS and assigned COM Ports 3 & 4 to the serial ports instead of COM Ports 1 & 2 to try and rule out a hardware conflict.
I am beginning to think the motherboard is faulty. Can anyone suggest anything else that might solve this problem?
Please note: There is no Device Manager in Windows 3.1, this was first introduced in August 1995. As such, I do not know how to check for hardware or resource conflicts in Windows 3.1.
Many thanks,
Richard
Many thanks,
Richard
