problem with MSN Messenger 6.2 and ICS
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Hi everyone,
I use my laptop (PC A) connecting to the Internet via an USB-ADSL Shared
Internet Connection on a desktop PC (PC B). The two PCs are connected with a
10Base-T Hub.
PC A: WinXP Home SP1, IP 192.168.0.2, No firewall
PC B: WinXP Pro SP1, IP 192.168.0.1, No firewall
My problem is that with Windows Messenger 4.7.2009 I can use video/audio
connections but unable to send/receive files. If I try to use MSN Messenger
6.2 I can send/receive files, but no audio connections (actually, I can
listen but unable to send audio signal) or I can send video signal, but
unable to receive audio.
Both Windows Messenger and MSN Messenger work properly only if I connect to
PC B.
Does anyone know how to fix my problems?
Thanx in advance.
Cloningman
xxxgifalone@tiscali.it (remove xxx)
Why don't you upgrade so that both the laptop and the PC run the same
version of MSN messenger. Windows messenger has less functions than MSN
messenger and is probably one reason why you don't have functionality
between the send & receive between the both.
"cloningman" <xxxgifalone@tiscali.it> wrote in message
news:gpNod.387796$35.17389782@news4.tin.it...
> Hi everyone,
> a
> 10Base-T Hub.
> Messenger
> to
> PC B.
> Thanx in advance.
> Cloningman
"Philippe L. Balmanno" <plb2862@cox.net> ha scritto nel messaggio
news:gpSod.139946$bk1.111901@fed1read05...
Maybe I have been unclear. I do apologize.
I have the same version of messenger on both PC. When I use Windows
Messenger on PC A, I can chat and audio/video send/receive, but I'm not able
to send files. When I use MSN Messenger on PC A, I can chat and send/receive
files but I'm unable to send my audio, although I can send video.
Please, help me if You have some advices.
Thanks in advance.
Stefano
gifalone@tiscali.it
"cloningman" <xxxgifalone@tiscali.it> ha scritto nel messaggio
news:GcXod.389495$35.17469581@news4.tin.it...
able
send/receive
I've just installed MSN Messenger 7 Beta. I've solved my problem.
What was the matter with my MSN Messenger 6.2? Does anyone know?
Cloningman
