problem with my 21inch mitsubishi Help?!
Sigma
221
I have a 22inch diamondpro 2020U. Ive had it for about 4 years. A coupe of weeks ago the monitor turnied on but no picture whatsoever. I just gave it a tap on the side and then it began to project a picture. This morning the same thing happened and it just wont project any image or anything or anything. I hoooked up my other monitor from my other cpu to the cpu running the 22 inch and it worked fine so its a monitor problem. Is there any way to fix this thing or it totally shot? Thanks for your help.
XP2500<b>@</b>2300Mhz(11.5x/200)
A7N8X DLX
Corsair XMS-LL PC3200 2x256
ATI Radeon 9700Pro
Maxtor 80gig ATA/133 8mb
SLK800U/Tornado combo
Lite-On 52x24x52 CDRW
3Dmark01=16000
some places can fix this sort of thing or at least have a look at it...
if it's a problem with the electron gun inside could be expensive or could be cheap like a transistor...
Trust me I know what I'm doing... ooops, grab the cat...
okay just after i had order a new 21' and its on its way here tommorrow, my monitor suddently decides to work. Is this just a fluke thing?
A7N8X DLX
ATI Radeon 9700Pro
3Dmark01=16000
