[SOLVED] problem with my fan and motherboard
Oct 21, 2020
9
you are correct, I do. But I have a 3 pin fan header and a 4 pin RGB hub cable. The 3 pin does not fit in the JCORSAIR1 on the top left
That 3 pin fan connector will fit into any of the 4 pin SYS_FAN header on the motherboard... the connector has guides and it'll fin right in:
You can plug it in directly in any of the 4 pin chassis fan connectors (CHA_FAN/SYS_FAN printed on the board) on the motherboard.
Looks like this:
You'll be able to directly control the fan from the BIOS afterwards.
I do not believe those ports are on my motherboard, I pretty sure there is a RGB header but I'm not sure there is a fan header
