problem with my - GPU 511°C? Is it fried?
Jirka Novak
9
Hey guys, firstly sorry for my bad english
I have laptop with 2 Graphics cards - AMD R5 M230 and Intel HD4400 (integrated). MSI Afterburner shows the temperature of GPU 511°C, 0 Volts and 0 Mhz. Intel HD4400 works normally - about 40°C, 55°C when I play unassuming games. However, AMD R5 M230 has bigger performance, but when I play games works the integrated graphics and not AMD. Do you think that´s my graphic card fried? Is here any solution? Thank you for your advice
hey man.
cant for sure say that its fried.
But to be sure,try taking the AMD R5 M230 off ur laptop.
you will probably see if its fried or not.
(sorry for my bad english)
just take off the graphic card carfully to check if its good.
and theres no other way to be sure or to fix it without
taking it off your laptop
Pretty much. Sounds like MSI Afterburner is not reading the information properly from the GPU. That temperature would surly result in afire that would destroy the laptop.
I suggest trying the latest drivers from the manufacture of the laptop and then see what happens.
Every 10 seconds temperature drop on normal temperature about 35 - 40°C, so probably the graphic card does not totally fried. As I said other programs measured 511°C too, so maybe faulty sensor? But why while I play games works integrated graphic and not the AMD?
No, normal works the integrated graphic card Intel HD4400, MSI Afterburner shows on R M230 only 511°C, 0 volts and 0 Mhz.
But every 10 seconds the Temperature drop from 511°C to about 35-40°C
