I just bought a VisionTek AMD Radeon HD 7750. I did everything step by step; uninstalled the old driver, turn it off, open it up, put 'er in, loaded the computer...
when i went to install the new drivers, everything started smoothly. A couple minutes into the installation process, my monitor went blank, and went into power save mode. I initially thought it was just part of the install process, but after 15 minutes, it still didn't come back on. I switched out monitors, and input method. When i first plugged the second monitor in, it showed me my desktop, but 15 seconds later, it too went into power save mode. I then restarted the computer, and everything seemed like it was fine. I checked out my new windows rating and let out a shout of approval. Then I loaded Tomb Raider, and decided to change some of the settings. I tried out one configuration, but decided i didn't like it, so i didn't keep the settings. The screen then went blank, as if to change resolution, but never came back on. Once it switched to a green screen, but then back to black.
I was told that I would be fine with this GPU in my computer, so was it just a bad driver install, or is this card just not compatible? PLEASE HELP!!!
