Question Problem with my ram
Aug 19, 2019
43
So i ordered 8x2 gb ram 1600mhz and lately found out that they are working on 1333mhz. I tried switching to 1600mhz, but it kept saying that overclocking is failed and i should go back in bios and switch back again.
My motherboard is H61M-E and it supports 1600mhz as far as i know. Help would be greatly appreciated,Thanks.
Aug 19, 2019
43
1600MHz and higher frequency is supported by Intel 3rd generation processors.
I suggest listing your memory part number and/or link to it. You also did not list the CPU model number.
Maybe thats the problem? Cause i have i7-2600k 16 gb ram dual channel and gtx 750 ti
Unfortunately i cant tell the brand or model of psu but its 500watt
