Problem with my wireless adapter D-link DWA-132.
nimrod21
39
I'm a problem with my wireless adapter DWA-132.
I can download my files usually with great speed, but when I play online, the game "hangs" because of the internet connection. I can not explain, but it's a very strange lag. See, that's not my problem computer components (motherboard, video card, etc.), as they are updated and this problem happens in old games too.
I have already installed the drivers and reinstalled as well.
Use Windows 7 64-bit and
To rule out the wireless adapter being the issue, you should connect to your wireless router or modem with an ethernet wire to your port and see if the lag exhibits itslef. Most often the ISP's are to blame for the high ping times and if not then it can be a possibility that the server on which you're trying to connect to to game is seeing a high traffic from users/members.
Might I ask what games you're playing to see the abnormal ping times? In any case it'd be a good idea to pass on your full system's specs inclusive of your connected peripherals.
hi bro i have the exact same problem too with the same adapter, have you tried changing the adapter?
I'm having the same problem too.
Have you found any Solution?
