I bought some memory (listed below) for my motherboard, Intel DQ67SW running an I5 2400 3.1ghz.
APACER 8GB(2X4GB)DDR3 RAM MEMORY PC3-10600 1333MHZ 240-PIN CL9- P/N 75B83C1G120B
I have updated to the latest bios.
I use Dim slots 2 and 4, the blue ones (as stated by the manual), with a 2GB ram stick in each, everything is fine.
If I add one 4GB stick to dim slot 2, its fine, runs with 4GB ram, if I add the second to dim slot 4, my pc doesn't load, fans work, screen stays black. Both ram sticks work when alone, they just don't work together. Im not sure what this problem is, but I don't think it is compatibility as the ram sticks do work when alone.
Any help?
I want to get one last opinion before I return the ram sticks just in case someone knows how to fix it.
Any help?
