Problem with NFSU2
G
Guest
Guest
Archived from groups: alt.games.need-for-speed (More info?)
Hi all,
I have NFSU2 running on a laptop P4 1'6GHz, 512 RAM, ATI Mobility Radeon
7500 and Windows XP.
I have all settings to the low requirements, and the game works fine. But a
few minutes later, the game starts to run very slow without aparent reason.
At 2-3 fps.
The RAM used when it works fine its 70MB. When it start to go slow uses
125MB (165MB with the drivers provided by the laptop manufacturer).
Anyone know the reason?
thanks
jugator kirjoitti:
> Hi all,
> At 2-3 fps.
> thanks
Since it is a laptop, could it be possible that some sort of power
saving mode kicks in (it shouldn't`)? Check power management in Control
panel.
"vellu" <velimala@hotmail.com> escribió en el mensaje
news:cttcvu$cjs$1@phys-news1.kolumbus.fi...
> panel.
I discard it. It's a laptop, but I use it as a normal PC because the battery
doesn't work :). I have the power management configured like a normal PC.
I supose that the problem is the OS. I think that the use of 165MB of RAM is
not normal.
thanks
On Thu, 3 Feb 2005 16:11:36 +0100, "jugator"
<jXuXgXaXtXoXr@escharlamotor.org> wrote:
> I think that the use of 165MB of RAM is not normal.
>thanks
The minimum RAM requirment is 256 MB. Maybe that's the problem -
you're paging to hard drive after a couple minutes and the game
collapses from slowness.
well, the problem is fixed.
There was a heat disipation problem of the ATI chip. I opened the laptop to
limits that I didn'twant to reach :), I cleaned it a lot and used Thermal
Compound. Now works fine :)
thanks
esto es un mensaje de Usenet,
no de un foro web de mierda
jugator EChMotor#140
Skoda Fabia 1.4MPI 2001-2003
Suzuki GS500 '02 2004-20__
