Problem with Norton Liveupdate
G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
Hi,
I have just installed Norton Internet Security 2005 on my Win ME PC.
The installation went without a problem.
However when I use liveupdate to update the software, once the updates
have been downloaded and Norton starts to install them, the screen
turns blue and freezes.
The only way is to hard reboot the PC.
Once the PC is rebooted none of the liveupdates are installed.
Can anyone advise.
Thanks very much for any guidence.
Phil.
G
Guest
Guest
"portchey" <portchey@gmail.com> wrote in message
news:8440294b.0503050918.14a8a2c2@posting.google.com...
> Can anyone advise.
You will no doubt be advised by the experts here to removed Nortons from your
system. They have good reasons for this advise, especially if you're using
anything more than just Nortons Anti-Virus (which I note you are).
But, short of removal, you might try disabling Windows System Restore. At least
when you find Live Update is telling you it wasn't do to anything more complex
than just virus definitions. I've found that Nortons doesn't play nice with SR,
especially when LU is doing anything other than simply downloading virus
definitions. Also, on some systems, it can help to not let Live Update run
automatically on system start up, but to use it manually instead.
- Bill
G
Guest
Guest
Uninstall Norton and return to vendor as not fit for purpose - Norton and
Win ME don't play well!
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
> Hi,
> Can anyone advise.
> Phil.
G
Guest
Guest
Hi Bill and Noel.
I beleive I can get the updated Virus Definitions from Symantecs site
and install them manually but where would I get the other updates,
like ad blocking etc.
Thanks for any advice.
Phil.
G
Guest
Guest
While Mr. Leary's advice re: disabling System Restore before running
Symantec's Live Update on a WinME machine may permit Live Update to run
successfully, I would comment that it is rather like removing all the brake
fluid from one's master cylinder before driving down to get the Sunday
newspaper --- not good!
If the Live Update session kills winME, one is left with the possibility of
running SR under DOS to recover.
To paraphrase Mike Maltby's frequent comment in the WinME ng's, don't take
off the parachute when "Norton stunt flying".
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/security/protect/default.aspx
Your cooperation is very appreciated.
"Bill Leary" <Bill_Leary@msn.com> wrote in message
news:p6-dneYkwNpkl7ffRVn-pA@giganews.com...
> > Can anyone advise.
your
using
least
complex
with SR,
run
> - Bill
G
Guest
Guest
Since I refuse to use ANY Norton software on any machine I work on regularly
(and uninstall it by default on any client's machine unless I have VERY good
reason not to!) I have no idea - and could possibly not care less.
Symantec's support pages would seem to be the place to go - if you can find
your way through the maze.
news:8440294b.0503060305.7b25b8c4@posting.google.com...
> Hi Bill and Noel.
> Phil.
G
Guest
Guest
"Jack E Martinelli" <jemartin_DELETE@NO_SPAM_gis.net> wrote in message
news:%23ZG8aojIFHA.2276@TK2MSFTNGP15.phx.gbl...
I wasn't proposing leaving it turned off, though I suppose I wasn't clear on
that point.
My own experience with Nortons is limited to NAV only, 2003 and now 2005. After
the initial install, it pulls down a large number of updates, including to the
programs themselves. I've had few problems with 2005, but when I did 2003 I had
problems whenever it did program updates. I quickly traced these to conflicts
between it and SR. Other problems, including startup ones, were also SR
conflicts Since the OP has the much larger suite, I thought that perhaps
disabling SR might be helpful.
Since I was sure numerous folks would suggest dumping the package, I figured it
would hurt if I put out a suggestion on surviving it.
I don't recall ever reading that, but it's both colorful and useful.
I'm aware of the feelings of the group on Nortons, and my experience has just
been different. At least relevant to NAV. The rest of the suite, on the other
hand, scares me and always has. Sometimes your milage can vary a great deal.
- Bill
G
Guest
Guest
Hi All,
Looks like the best thing is for me to uninstall it then and look else
where for a package that will work with Win ME.
Maybe, ultimately, I should dump Win ME and upgrade to Win XP pro.
Thanks for everyones help and guidence.
Phil.
G
Guest
Guest
Phil,
Remember though that Norton can cause problems regardless of the operating
system on which it is installed.
Mike Maltby MS-MVP
mike.maltby@gmail.com
G
Guest
Guest
Hi All,
It seems that the installing of Norton, regardless of the operating
system is a lottery.
I have another PC that is running Win XP pro with Norton internet
security 2004 and Ghost 9.
No problems yet.
Other people have had a nightmare with this conbination.
I must be lucky on this PC.
steve
2,366
Just my 2 penneth !
I too had problems with the full install of Norton Suite on Win ME.
I then tried just putting on Norton Anti-Virus JUST on its own ....
problems there too ... may a reformatting of hard drive in ,ost cases
to reatore normality ... until I went back to NAV 2002 (any newer and
loads of problems !) and had that on months now witt NO PROBLEMS AT
ALL.
Seems stuff later than 2002 is not really compatible with Windows ME
... well not in my experience anyway.
Steve
On Sun, 6 Mar 2005 11:21:19 -0000, "Noel Paton"
G
Guest
Guest
"Steve" <steve@removethis.parity.demon.co.uk> wrote in message
news:m6f831dotgn6v1999orogpflomnbmhr7bu@4ax.com...
> Just my 2 penneth !
> ALL.
This feels like a shell game. *I* had constant minor problems and occasional
major ones with 2003, but have had very few problems with 2005. Anti-virus
only. I wonder if it matters what else you've got installed. Or, like HP*
stuff, what order you install things in. Or ???
- Bill
* I have an HP printer, scanner and DVD burner. While re-installing ME I
discovered that if I didn't install their respective drivers and updates in just
the right order they wouldn't all work and, in some cases, ME wouldn't even
boot. I was incredibly lucky that when I called HP about one of the problems
that the phone person actually admitted that the problem existed and, although
she wasn't sure how to get around it, suggested things to watch out for.
G
Guest
Guest
....it'll happen!
In fond memory of one of life's Gentlemen - Alex Nichol
http://www.aumha.org/alex.htm
> Just my 2 penneth !
> ALL.
> Steve
>>regularly
>>good
>>find
Similar threads
