Question Problem with nvidia driver Latencymon
Jun 22, 2025
After updating my graphics card 5070 ti and installing new NVIDIA drivers, I started experiencing micro-stuttering while watching YouTube. I've tried a ton of solutions and can't get rid of it. The thing is, if I disable the NVIDIA driver and use integrated graphics, everything works fine, but when I enable it again, the stuttering returns. It’s likely some kind of driver conflict.I've already tried a bunch of different methods, but nothing helps.
There are 2 screenshots below, the drivers are disabled on 1 and enabled on the other
View: https://imgur.com/a/cdoo2n9
LATENCYMON
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:11:20 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: WIN-JVQOB5N34RG
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: B650 AORUS PRO AX, Gigabyte Technology Co., Ltd.
BIOS: F34a
CPU: AuthenticAMD AMD Ryzen 5 7600X 6-Core Processor
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 31862 MB total
CPU SPEED
Reported CPU speed (WMI): 4701 MHz
Reported CPU speed (registry): 4691 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 13159,80
Average measured interrupt to process latency (µs): 6,482729
Highest measured interrupt to DPC latency (µs): 13156,50
Average measured interrupt to DPC latency (µs): 2,805672
Latest posts
