nitinvaid20 :
its a GTX 950 GPU and its good one you can play games with it make sure to use the display DVi or hdmi to insert it in GPU not on motherboard
I think you are just excited to find out that your PC has GPU and you created a thread😀
I will get a Hdmi cable and plug it.
And if you said that my gpu is a good one will it run Overwatch on 40 fps on medium XD
Do I need to change the graphics in the BIOS to the GPU or let it on auto?
