Question Problem with operating the switch on Bose QuietComfort Headphones ?
MasterYoda327
226
6
10,585
[Moderator edit to break up solid block of text.}
I have been using my Bose QuietComfort headphones for listening to audio in both wired and wireless mode. They perform nicely for me, especially in noise-cancelling mode.
However, the one issue that I have had lately is that sometimes either my finger loses its grip on the headphones' switch or releases it too soon when I push it from off-mode to on-mode to enable noise-cancelling mode.
The switch ends up positioned between the off and on positions without enabling noise-cancelling mode most of the time.
At first, I was concerned that there was a defect or problem with the switch, but upon testing it, it appeared to perform its proper functions for off, on, and Bluetooth pairing modes and stayed in the locked positions it was designed for. I also confirmed during my test that the switch could sometimes get stuck between the on and off position as already mentioned, but could be either pushed back to the off position or a little further to get it to the on position.
Unless someone points out an issue that I am unaware of with the switch, as far as I could tell, the switch for my Bose headphones does not appear to be broken or defective. I think Bose should make the switch a little longer on its future noise-cancelling headphones for an easier grip for a user's finger(s).
Out of curiosity, has anyone else had issues gripping the switches on their Bose QuietComfort headphones or any other models of Bose noise-cancelling headphones and had the switch stuck in between two different mode positions due to either losing their grip on the switches or releasing them too soon? If yes, do you also believe the switches should be longer for a better finger grip?
Thanks in advance.
Probably not much you can do with respect to the design and feel of the switch.
You could send Bose some sort of comments/complaint but that is unlikely to resolve anything.
Depending on where the headphones were purchased you may be able to submit some sort of "verified purchaser" review based on your post here. Just be fair and honest in the review.
Overall though, the one thing you do is to just get in the habit of taking a moment and being very deliberate and careful when pushing the switch from off-mode to on-mode. Or vice versa.
Keep the switch clean and dry. Which should be being done anyway - for the entire headphones.
Once you get accustomed to paying just a bit more attention and taking a bit more care it is very likely that the switch use will become mostly automatic.
Also likely that the switch will "break in" a bit more and become easier to turn on and off.
Just my thoughts on the matter.
Reactions: MasterYoda327
