problem with PC, seems like space bar is stuck
Themkman
25
Hi guys
I have this really random problem, this is the 3rd time this has happened to me, every other time i have just had to re-install windows to get it to stop, Basically PC (windows 7) acts as if the space bar is constantly being pressed down, its not, I have removed the space bar, still does it, changed keyboard, still does it, removed keyboard, still does it.....
so what the hell is happening, it always seems to activate while i am playing video games, but sometimes months apart, I really do not want to wipe my PC again and install, Also when i restart/shut down the pc it stops for a while then starts again,
has any one got a clue??????
Any help will be very much appreciated
its hard to tell as, when i restart or shut down the PC it stops, for what could be 10 mins or a few days, and as i said it only seems to get activated in games, suddenly a game will stop responding, and then the space bar issue is there, I have been searching through google, to see if there is a command on the keyboard that might make it do something like this, but found nothing.
I did the same thing, but only came up with viruses as the cause. So with that in mind, perhaps a run through with Malwarebytes would be a good step.
This was the result, could any of them caused this to happen????
Malwarebytes Anti-Malware (Trial) 1.75.0.1300
www.malwarebytes.org
Database version: v2014.03.03.07
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 11.0.9600.16518
MK :: PAUL [administrator]
Protection: Enabled
03/03/2014 21:44:07
mbam-log-2014-03-03 (21-44-07).txt
Scan type: Quick scan
Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
Scan options disabled: P2P
Objects scanned: 218471
Time elapsed: 2 minute(s), 42 second(s)
Memory Processes Detected: 0
(No malicious items detected)
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Registry Data Items Detected: 0
Folders Detected: 0
Files Detected: 11
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$R6WOIWB.exe (PUP.Optional.FilePile.A) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$R82TMSZ.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$R9YL16Y.exe (PUP.Optional.GoForFiles.A) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RL2WXZ1.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RLJ5DBT.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RN5B47E.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RO17IEF.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RRUN7Z3.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RUS0Y5Q.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-500156686-1210475012-2337821163-1000\$RXQX1RT.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
C:\Users\MK\Downloads\Download.city.car.driving.Torrents.KickassTorrents__2721_i321960725_il3579839.exe (PUP.Optional.InstallMonetizer) -> Quarantined and deleted successfully.
