Using a pc as a stand alone Minecraft server so I needed to set this up with a static IP on my home network so I could set up port forwarding on my router.
I tried assigning an IP address both lower or higher than the DHCP pool on the router. When I do this I can ping the server and run minecraft on the server with no problems within the LAN but when I try to port forward to this IP I always get the error "This IP address should be in the same Subnet as the LAN IP address.
I double checked and the Subnet is correct and if I try port forwarding to an IP address within the DHCP pool range it is accepted so it seems I cannot port forward to a static IP address.
What am I missing here?
