Hey,
I've been trying to optimize/overclock my system for Fallout 4. I downloaded CPU-Z, and it was reporting my ram differently than I expected. I did some research, and people said that in your BIOS you need to enable XMP - I did that, and on the memory page it has the correct memory timings. However, CPU-Z still reports the wrong timings. And when I look in the BIOS at the section for "current system stats", the timings are also wrong.
My relevant system specs:
Gigabyte H97M-D3H 1150 (supports 1600mhz ram, using latest F11 firmware)
i5 4570 (not overclockable)
G.Skill Ripjaws X 2x4gb 1600mhz, 9-9-9-24 (being reported as 11-11-11-something)
One thing I have noticed, is that in the BIOS everything seems to be locked at auto, I can't overclock even the Ram, change any timings, etc. Im surprised, even though my CPU is not overclockable, I would
Here is my CPU-Z info:
I'm hoping someone can help - I'll try to post some screens from my BIOS as well. Frustrating to buy overclockable ram only to have it not even reach its stock potential!
Code:
CPU-Z TXT Report
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 4570
Codename Haswell
Specification Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 3591.4 MHz
Multiplier x Bus Speed 36.0 x 99.8 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 36x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 36x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
TSC 3192.6 MHz
APERF 2892.8 MHz
MPERF 2727.7 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 36°C (96°F) [0x40] (Core #0)
Temperature 1 37°C (98°F) [0x3F] (Package)
Power 0 15.89 W (Package)
Power 1 4.20 W (IA Cores)
Power 2 1.06 W (GT)
Power 3 10.63 W (Uncore)
Power 4 1.53 W (DRAM)
Voltage 0 0.98 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Chipset
Northbridge Intel Haswell rev. 06
Southbridge Intel H87 rev. C1
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual
Memory Frequency 798.1 MHz (1:6)
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 28
Row Refresh Cycle Time (tRFC) 208
Command Rate (CR) 1T
Uncore Frequency 3591.4 MHz
Host Bridge 0x0C00
MCHBAR[0x5004] 0x0061001000610010
current channel 0
MCHBAR[0x4000] 0x083341841586716B
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD0000000000)
Size 4096 MBytes
Max bandwidth PC3-12800 (800 MHz)
Part number F3-12800CL9-4GBXL
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-22 @ 457 MHz
JEDEC #2 7.0-7-7-19-26 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 685 MHz
JEDEC #5 10.0-10-10-27-37 @ 761 MHz
JEDEC #6 11.0-11-11-28-39 @ 800 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 9.0
Min tRP 10.88 ns
Min tRCD 10.88 ns
Min tWR 15.00 ns
Min tRAS 29.63 ns
Min tRC 40.88 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 9.0-9-9-24-33-2T @ 800 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
Max CL 9.0
Min tRP 10.88 ns
Min tRCD 10.88 ns
Min tWR 15.00 ns
Min tRAS 29.63 ns
Min tRC 40.88 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
Monitoring
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 0.80 Volts [0x43] (CPU VCORE)
Voltage 1 2.03 Volts [0xA9] (VIN1)
Voltage 2 2.06 Volts [0xAC] (+3.3V)
Voltage 3 3.37 Volts [0xA7] (+5V)
Voltage 4 3.22 Volts [0x43] (+12V)
Voltage 5 -6.96 Volts [0x91] (-12V)
Voltage 6 -6.14 Volts [0x80] (-5V)
Voltage 7 2.82 Volts [0x8C] (+5V VCCH)
Voltage 8 1.58 Volts [0x84] (VBAT)
Temperature 0 30°C (86°F) [0x1E] (TMPIN0)
Temperature 1 -54°C (-67°F) [0xC9] (TMPIN1)
Temperature 2 28°C (82°F) [0x1C] (TMPIN2)
Fan 0 873 RPM [0x305] (FANIN0)
Fan 1 1140 RPM [0x250] (FANIN1)
Fan 3 445 RPM [0x5EE] (FANIN3)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
Register space LPC, base address = 0x0A30
