Question Problem with RAM XMP prfile.
Jul 26, 2022
So I built new pc with 32GB (2x16GB) 3200MHz CL16 Ballistix Black, and when I enable XMP, I got crashes in games, such as 0xc0000005 error, acces_violation, etc. And when I turn off XMP ram is running at 2400MHz and I got no errors, I also tried turn off XMP and manually set to 3200MHz, but I also got errors. This is strange because people tell that this RAM is capable of even 3600MHz OC.
Motherboard: Gigabyte B560M DS3H V2
Cpu: i5-11400f
Here is my SPD if it helps. also here is this View: https://imgur.com/a/20HxRmz
View: https://imgur.com/a/ofQIHl6
Cpu: i5-11400f
Was this ram a kit?
Fitted in the proper slots?
Proper bios and mobo drivers?
Ram modules should be in slots A2, B2 (grey color slots).
Overclock manually.
Set
Latencies to 16-18-18-36,
Command rate to 1T,
DRAM voltage to 1.35V
Set DDR frequency to 2400mhz. Test. This should work fine.
Then increase frequency one step at the time and test again:
2600mhz, 2800mhz, 2933mhz, 3000mhz, 3200mhz.
At some point it will probably fail. Then return to previous settings that worked.
yes ram kit, fitted in propper slots, newest bios and drivers
just to be sure, BIOS version F7 is installed?
to have a look what the problem could be:
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
Reset the BIOS by jumper clrCMOS or JBAT or similar (eventually you will have to set the boot priority correctly after that)
set XMP profile again
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
Was windows freshly installed with this system?
