• Our team is working to address issues posting quotes or media to the forums. Please bear with us as we get this sorted out.
Question Problem with Realtek Dragon RTL8125AG on ASRock TRX40 Creator motherboard ?
Shamanji
5
Amd Threadripper 3960x
Cooler Master MASTERLIQUID ML360 RGB TR4 EDITION WITH RGB CONTROLLER
Asrock Trx40 Creator
32GB G-Skill 3800Mhz Cl 14-16-16-36
Super flower leadex platium 2000w
2x Zotac 980ti !i know old"
1x samsung 950 pro 512Gb nvme ssd
1x 2Tb 850 evo 2Tb
1x 2Tb 980 Pro
7x seagate 4tb
Mad cats Keybord
Logitech G903 Hero 25k 25600Dpi Lightspeed
Logitech Poweplay
I have started to getting a problem with this dragon rtl8125ag wich is that in device manager it stated that the dragon rtl8125ag is working fine but when ever i out a lan cable in or dossent light up or tell me that it's connected at all.
ive tried 5 different cables, 5 different routers and tried many lan ports on the router's.
What could be the cause of this, nothing seems out of the ordinary when i look inside the lan port.
could it be windows driver problem cause i tried atleast 10 different driver's versions.
dos it disable the lan port when i put things in certain slot on the mobo cant find anything in the user manuel about it.
dont know if there is a firmware that could fix it.
What coudl be wreong here since my AQUANTIA® / Marvell 10G LAN works just fine just not the Realtek 2.5G LAN :(
Anyone have any suggestions?
