Is your monitors native resolution set to 900p? It should automatically configure the resolution to your systems set resolution, except if you're playing much older games. A lot of newer games set the resolution to 1080p as it is still a popular resolution to play at. I mean, I don't know why manually setting the resolution is a problem, it doesn't take that long. Hope this helps.
