Question Problem with resolution
huszentiszilas
12
Hello,
First of all i have an ASUS TUF GAMING RX 6700 XT 12Gb card with an AMD Ryzen 5 5600X CPU and i'm currently using a Windows 11 system, my monitor ig an LG wide 2560x1080 60Hz connected via an HDMi 2.0.
About 2 days ago i updated my pc from something Win 11 to Win 11 2022-01. (I used Win 11 for months now). After the update installed, my resolution went from 2560x1080 to 1920x1080.
So i thought nothing of it lets install the new AMD driver did it nothing changed... so i DDU-d my PC and i got it back to 2560x1080 okey lets install the driver as soon as it is done it goes back to 1920x1080 hmm strange...
Lets rollback the patch nothing changes okey..... i'm getting annoyed lets do a Win 11 install okey i did it i install the driver and it works, i restart the pc and resolution is back to 1920x1080.... i tried Win 10 same result....
Gaming is working without an issue other than that i cant go past 1920x1080, no crashed or anything full quality perfect fps. I can boot into safe mode than the resolution is again good 2560x1080.
The problem is as soon as i install the Amd driver it goes to 1920x1080 and i cant do anything about it. I checked event viewer and it gives some error i know event viewer is kinda nothing but tbh i dont have any clue so i'm hanging to any strings.
View: https://imgur.com/a/DqDWdFx
Thank you inadvance.
