Problem with resolution
Arrri
I have ATI Radeon HD7970, Dell monitor with max resolution: 1920x1200 and windows 7 64bit.
On starting computer:
1) BIOS - all displayed OK
2) Windows loading - all displayed OK
3) Logging in screen - not displayed - monitor is telling me, that best resoultion is 1920x1200. It looks like graphics card is using too high resoultion.
All I can do is putting computer to sleep, waking. Then all works perfectly.
did you download your graphics card driver? try that.
if that doesnt work go to Control Panel> Appearance & Personalization>Display>Adjust Screen Resolution and set resolution to 1920x1200 in dropdown box
I downloaded and installed drivers from amd. After update problem still exists.
I'll try to reinstall ;/
Latest posts
