Hi, i have a problem with my nvidia gtx1070, when i try another resolution than 4k or 1080p (via hdmi) the refresh rate go down to 30hz (in nvidia control panel) and i don't no why because before this card i had an rx480 and i could change the resolution between 1080p and 4k with no problem like 1440p, 1600p, 1800p.
Before i installed the gtx1070, i ran guru 3d driver swapper to remove the amd driver completely.
There's something strange, if i choose 1440p (and even 1080p) from windows screen configuration, it shows at 60hz but the colors seems to be only green and red o.o.
My pc is running windows 10 with the anniversary update installed, maybe this update break something because after this update i had some issues to update amd graphics driver and some times it happens with nvidia.
Right now i'm planning to do a fresh install of windows.
Any suggestions?
Thanks a lot.
P.d: Sorry by my english.
Any suggestions?
Thanks a lot.
