Hi I built my first pc yesterday, here is the build.
https://pcpartpicker.com/user/redbioniclem/saved/#view=8bvdmG
I think the errors I might have done were putting too much thermal paste or not handling everyhting correctly, or maybe im just overreacting.
When I first turned on the pc it was fine(i even went on google and archives to see everything, pc was fully functional until i turned it off) after finishing installing everything. Then I was happy and tried moving it to the place were I usually put my pc and closing the case. Even though I had connected the cpu cooler in the wrong place, which I later fixed)
Also, I added the ethernet cable and the 2 audio on the front of the case.
When I tried the pc wouodnt turn on and the red led light was on saying that the cpu was not being recognized.
I took off the cooler and cpu added a little more of thermal paste after cleaning the cpu a bit.
The system went on with the red light and for a moment it that led light went off and a couple of seconds later on again. I had the cooler not connected to the motherbord. When I connected it after turning off the pc, no cpu detected.
I took off everything to re do the flash bios after resetting the motherboard.And I am thinking maybe I didnt screw the cooler enough and the cpu went loose all those times.
Please, help.
Please, help.
