Question Problem with Sades sa-903 recognition
AiMagicBot
12
I just recently bought Sades sa-903 headset and when I try to install the driver it shows me that the headset is not connected.
The computer recognizes it as "USB PnP sound device" (and I think it should recognize it as "USB audio device" or somthing like that).
I also tried to install the driver manually through the "device manager" but when I do it says "This device cannot start (code 10)".
I tried it also on different PCs and I got same results.
CPU: Intel i7 5930K
Motherboard: Gigabyte GA-X99-UD4-CF
Ram: Kingston HyperX Fury DDR4 2133MHz C14 4x8GB
SSD/HDD: C;SanDisk Ultra II 480GB D;Seagate Barracuda 7200.14 1TB E;Seagate Barracuda 7200.12 1TB
GPU: Gigabyte GTX 980 Ti G1
PSU:
Chassis:
OS: Windows 10 Pro 64bit
Thank for those who's trying to help.
Did you source your driver from this link? If so, try installing the driver under an elevated command, i.e Right click installer>Run as Administrator. You also forgot to mention the version of the OS you're on and the rest of your specs on your system. List them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
I tried that either, didn't work. But thank you though!
