Just bought a new Sapphire Radeon 6870 GPU for my new pc. Without the card, everything works just fine and I have no problems doing anything with the on board graphics on the i5 2500k. When I installed the card and started up my pc (everything seems to work perfectly), the resolution was restricted to 800 by 600 (because I have not yet installed the drivers yet). I went to Sapphire's website and download the drivers, installed and restarted my pc. It gets up to where windows 7 shows the loading screen with "Microsoft Corporation" written on the bottom and then the screen goes completely black and stays like that. I'm still able to go into the bios and load windows in safe mode using the card, but I cant go into normal windows (because of the black screen after the loading screen). When I remove the card from the motherboard and plug my monitor into the integrated gpu port, everything continues to work fine. I tried using the drivers from the amd website directly and I still have the same issue. As soon as I install the drivers and restart, I get the same black screen after the windows loading screen. It seems to be some sort of driver issue. Sapphires tech support is a hassle (in my experience), and I would really appreciate it if someone could help me out before/while I try to get in contact with tech support.
I never had a card do this to me before 😱
My specs:
Core i5 2500k at stock (for now)
ASrock pro3-m z68 mobo
G.Skill 4gb DDR3 1600 ram
Antec 520w PSU
Sapphire Radeon HD 6870 1gb gddr5
Windows 7 Ultimate 64bit
My specs:
Antec 520w PSU
