Question Problem with SB AE-5 headset output
Jose Luis Lopez
6
Hello,
I bought an AE-5 sound blaster but there is a problem, when I use the headset output the games have a slight micro stuttering (only in the games), but when I use the direct mode the problem disappears, also it is fixed when I virtualize the headset in the speaker output.
I tried with sound blaster Command and connect 2, with different drivers but the problem is the same.
In summary: the problem is only fixed in direct mode and by virtualizing the headphones in the speaker output, but I want to use the headphones output.
Specifications:
i7 7700
16gb ram 3000
RX580
SB AE-5
x2 SSD 1tb
Greetings and thank you!
